Activity › Forums › Adobe After Effects › Working with After Effects and Wacom Intuos 4
Posted by Oscar De la calle on January 29, 2011 at 3:32 pmHello,
I´m considering to buy a Wacom Intuos 4 to work with After Effects and 22″ dual monitor. I´ll not be using to illustrate, only to draw masks and navigate on the interface.Is the small size enought and do a good job?
In the studios where I work there are L size but for my kind of work maybe are very, very bigs.Thanks.
Walter Soyka replied 15 years, 7 months ago 4 Members · 6 Replies -
Tudor “ted” jelescu
January 29, 2011 at 6:29 pmFor what you described that size is fine- also good for travel with a laptop.
Tudor “Ted” Jelescu
Senior VFX Artist -
Spencer Tweed
January 30, 2011 at 7:17 amThe Wacom is pretty accurate, so little motions can go a long way. I have a medium and love it, but think that I’d do fine with a small.
I would go for the bigger if I had a choice, but like I said the small should work great.
– Spencer
Oscar De la calle
January 30, 2011 at 6:41 pmThanks for your opinion Ted and Spencer.
Finally I think I´ll buy small size, I hope that small works fine with my dual monitors.Thanks!
Spencer Tweed
January 30, 2011 at 9:21 pmNo problem.
The Wacom products have a really cool way of dealing with dual monitors. Basically there is a button on the side that when you hit it you can cycle through monitors. It works out pretty well, but if you don’t like it you can change that setting in the preferences.
– Spencer
Walter Soyka
January 31, 2011 at 6:39 pm[oscar de la calle] “´m considering to buy a Wacom Intuos 4 to work with After Effects and 22″ dual monitor. I´ll not be using to illustrate, only to draw masks and navigate on the interface. Is the small size enought and do a good job?”
In my opinion, no. I’d at least go for the Medium.
Personally, I find a Wacom on a dual-monitor system maddening. If you map it across both displays, you end up with a relatively small working area on the tablet (especially on smaller tablets); if you map it to a single display at a time, it takes a lot of discipline to remember to hit the Toggle Displays button as you move from one monitor to the other, and drag operations from one monitor to another are completely unnatural.
I cheat and use a 30″ monitor to try to get around these limitations.
Walter Soyka
