Activity › Forums › Apple Final Cut Pro Legacy › Working With A PDF in FCP
  • Working With A PDF in FCP
    Posted by Max Frank on May 22, 2008 at 1:23 am
    Couldn’t find what I’m looking for in the search.
    I have a 20-page PDF file that I’d like to work with inside FCP 6.0.3.
    Right now, each page updates on every frame.
    Is there a way to set what page I want FCP to read, and animate just that page?
    Or do I have to export the PDF to a tiff, or whatever – or screen-cap it?
    Any advice would be most helpful.
    Thanks in advance,
    Wayne
    Navarro Parker replied 18 years, 4 months ago 4 Members · 5 Replies
  • Andy Mees
    May 22, 2008 at 2:33 am
    I think importing each page as separate elements, as you suggest yourself, would be the best idea … as far as I know there is currently no fancy method of handling multipage pdf’s within FCP and I fear that such a fluffy feature is just the sort of thing the FCP devs would happily waste their time on … so please keep it quiet 🙂
  • Max Frank
    May 22, 2008 at 2:34 am
    Ok,
    Thanks, Mums the word.pdf
    Yours,
    Wayne
  • Craig Anderson
    May 22, 2008 at 8:18 am
    I’ve had mixed success with PDF’s in Final Cut – they usually bog my system down.
    But check out this handy dandy automator action, that extracts each page of a PDF to a separate jpeg.
    https://www.apple.com/downloads/macosx/automator/pdfpageextractor.html
    Then you can just import all the converted files and edit away.
    Craig
  • Max Frank
    May 22, 2008 at 1:19 pm
    Craig,
    This app is awesome – thank you SOOO much!!!!
    It’s going to be a VERY big help.
    Wayne
  • Navarro Parker
    May 23, 2008 at 2:58 pm
    I would suggest always working with uncompressed file form. JPEG is lousy at compressing documents with text.
    If you open your PDF in Preview.app and do a “save as…”, you can select any file format Quicktime supports — like PNG and TIFF — and it’ll save your pages as a bitmap that FCP can read.
    If you have Illustrator, you can import PDFs and export them as PNGs or TIFF which are both lossless.
