Activity Forums Adobe Premiere Pro Working with a lot of footage
  • Working with a lot of footage
    Posted by Deke Ryland on January 25, 2008 at 7:52 pm
    When you are starting a new project in Premiere Pro and you want to make a clip thats about 10 mins but you have about 3-4 hours of footage to pull your cuts from, what is your general workflow for sifting through that 3-4 hours of footage to find the stuff you want to use?
    Do you import all 4 hours of video into Premiere, then review each clip and delete the “bad” ones… later sequencing the good ones? Or do you cut out all the fat before you even get to Premiere?
    Would love to get your advice or suggestions on what your workflow for this is. Thanks!
    Steve Smith replied 18 years, 7 months ago 3 Members · 4 Replies
  • Vince Becquiot
    January 26, 2008 at 3:25 am
    With only 4 hours, you could do that, it shouldn’t slow things down. (well anything over a P4 2Gigs of ram).
    Use the source window, and go through your footage, then create smaller “sub clips” to sort things out. You can then begin working on your rough cut.
    Vince
  • Deke Ryland
    January 26, 2008 at 3:29 am
    Do subclips require a re-rendering of the HDV? In other words.. if I make a subclip… it doesn’t recompress anything, right? No downsides to subclips as far as quality-loss?
  • Vince Becquiot
    January 26, 2008 at 3:33 am
    No, no recompression. It doesn’t actually create a new clip, it just keeps that data inside the project file.
    Vince
  • Steve Smith
    January 26, 2008 at 9:44 am
    I use the bach capture feature. I frist hook up my DV camera and in the capture window, I play the tape. When I see a scene that I might use, I set the in and out points. and save them . When I save them, I give it a description I can that helps me in the final edit. With Pro, you can search fairly well for words that you entered during capture. I usually enter the descriptors in the description part of the save dialog box and then search later there. I have actually one huge project with all my films in it and when I want to find scenes of my daughter, I use the find feature. Aynway, back to the capture window. In the timecode portion of the capture window (lower right) I set my in point by clicking on “Set In”. I hit the start button, not the record button!!!. I preview the scene and when the scene changes I hit the !Set Out” button. Then I hit the Log Clip button and enter all the information I need. I do this for all the tapes, in your case all 4 hours.
    When _I have doene this and finished my story board, I then highlight the offline clips and hit F6 or File -> Batch capture. All of the clips that were offline and highlighted will now be batch captured. Premiere will prompt you to enter the correct tapes, but that’s all. And, the best partt, the batch capture will be performed in the background. Hope this makes sense and it really got me organized.
