Activity Forums Apple Final Cut Pro Legacy Working with 7D footage, EDL and bringing footage online
  • Working with 7D footage, EDL and bringing footage online
    Posted by Amy Verwayen on July 28, 2010 at 3:29 am
    I’m about to start work on a project filmed with a 7D camera. I was just wondering if there was anything I should know about working with this particular type of footage.
    I understand that I will have to do an offline and an online edit. I understand the basics of what is involved but have never had to do it practically myself. Could someone walk me through exactly what I have to do in Final Cut Pro. Eg. How to compress the footage, How to create the EDL through final cut and how to use it to bring the uncompressed footage online once its edited.
    Much appreciated 🙂
    Peter Pop replied 15 years, 9 months ago 3 Members · 3 Replies
  • Shane Ross
    July 28, 2010 at 5:48 am
    [Amy Verwayen] “I understand that I will have to do an offline and an online edit”
    Why?
    Drives are cheap…you encode the DSLR footage to ProRes LT…edit at that resolution, and then you are done. Even if you went to ProRes 422, you can still edit full res. You will NEVER refer back to the master H.264 files…ever. That isn’t an editing codec.
    Shane
  • Amy Verwayen
    July 28, 2010 at 10:17 am
    I don’t want to edit in h.264 because that would slow down the computer a lot but I need the final product to be as good a quality as possible when I finally export. I am new to working with HD footage. If you can just edit in the top quality what is the point of offline/online edits?
  • Peter Pop
    July 28, 2010 at 10:35 am
    I think that was Shane’s point. Unless you are restricted to dealing with USB2 drives or need high portability, There is little point in the traditional offline/online workflow.
    Convert the files from the camera to ProRes Lt or 422 (personally I still go 422) and edit with those files. Back up your camera ‘rushes’ for archive
    Canon provide a plugin for the L+T window of FCP that can do the job (and can also add a ‘time of day’ timecode).
    I work with 7d, 550d and 5dmk2 footage on a daily basis this way. I’ve never had any real problems.
