Activity › Forums › Apple Final Cut Pro Legacy › Working with 23.98 timebase
  • Working with 23.98 timebase
    Posted by Andrew Cross on July 11, 2012 at 5:43 pm
    (I’m in the UK)
    I’ve recently accepted to help a friend out by editing something for him.
    I work all day everyday in the same formats and settings ( which is pretty shitty cause things like this really catch you out). Although I had told him to always use 25fps unfortunately he’s gone and shot in 23.98.
    I realised whilst trying to export out a timelapse as I was consistently getting a General Error.
    Now to be honest I have no real idea what problems this can cause me. I’ve reset my sequence settings to match the footage but would really like to get a heads up on any potential problems it could cause me.
    Any help would be really appreciated.
    Andrew
    Doug Beal replied 14 years, 2 months ago 2 Members · 2 Replies
  • Andrew Cross
    July 11, 2012 at 6:15 pm
    I’m thinking to editing in the native timebase and produce quicktimes for that and then use a compression at the end of the edit to create a file for dvd?
  • Doug Beal
    July 11, 2012 at 6:21 pm
    We do that with a lot of 23.98 material. It works fine for both DVD and BluRay.
    I suspect there’s a bit of difference however getting to 25 fps as almost all of what we do is NTSC and 23.98 is an NTSC variant, hopefully you’ll post a follow up as far as what level of success you’ve encountered
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
