Activity Forums Adobe After Effects Working into two diferents formats
  • Working into two diferents formats
    Posted by Jose L garcia on May 24, 2012 at 7:55 pm
    Hey guys, wich is the right workflow about get two diferents output videos?
    I mean, i want to create 2 diferents outputs of my footage, 1080p and NTSC.
    Im asking if the right way to do that is just work in the higher one (1080p) and make the movie and then use some 3rd part soft to resize it to the NTSC? or is better to make it trough after effect or premiere?
    Thanks in advance
    Jose L garcia replied 14 years, 3 months ago 2 Members · 3 Replies
  • Jose L garcia
    May 25, 2012 at 1:57 am
    Thanks for try to help me, my english is really not good :/ mainly i want to know how to make it in diferent resolutions.
    My original footages are 1080P60fps, and want to make 2 formats of the video, one in 1080P and other for internet Standard Resolution.
  • Walter Soyka
    May 25, 2012 at 2:20 pm
    [jose l garcia] “Im asking if the right way to do that is just work in the higher one (1080p) and make the movie and then use some 3rd part soft to resize it to the NTSC? or is better to make it trough after effect or premiere?”
    Yes, work at 1080, then resize for NTSC. (If you are not letterboxing, do remember to keep the graphics 4:3 safe for center cutting, or be prepared to rework 16:9 layouts for 4:3.)
    I don’t think there’s a need for third-party down-scaling. Premiere Pro uses Lanczos resampling and bicubic interpolation [link]. I believe AE uses bilinear only.
    Walter Soyka
  • Jose L garcia
    May 26, 2012 at 3:50 am
    So premiere will be better for down-scaling.
    Another question, my videos are all files of 2gb size.
    i want to cut that videos in small ones each fight (are martial arts tournament) so i need to edit each fight to add socreboards and stuff like that like an broadcasting event.
    So wich is the best way to do it? just import the big file into AE and drop multiple copies of each big file into the timeline and resize it, or think that will be better to create small files and edit each fight alone and then put all together using premiere?
    Hope understand me:)
