Activity Forums Apple Final Cut Pro Legacy Working in vertical aspect ratio
  • Working in vertical aspect ratio
    Posted by Jeremy Mullen on August 4, 2008 at 1:00 am
    Here’s an open problem, with an invite to any and all with hints, suggestions, or cleverness of any kind:
    I am working a lot with video shot for a vertical aspect ratio, usually a standing figure, which is displayed on a perpendicularly installed LCD. Since the camera is rotated 90 degrees when shooting, and the screen is rotated 90 degrees for viewing, I don’t need to worry about rotating the footage. The problem is that it is (very) irritating to work with sideways footage – particularly as there is a lot of text to punch in. I could turn my whole 2nd monitor on its side, but then if I want to have the timeline or anything else on it, it is unusable. I don’t currently have a separate (3rd) external monitor, either – just a dual-screen computer setup, which is plenty most of the time.
    I would LOVE it if there was a way in Final Cut to rotate just the view of the windows. Otherwise I rotate all the footage to work with it and then rotate it back. But what if I could just tell FCP that I wanted to work at a 90 degree angle? My dream is that there is someone out there more clever than me with scripting who could figure out how to make this possible. I put it to you. What do you say?
    Jeremy Mullen replied 15 years, 5 months ago 4 Members · 5 Replies
  • Arnie Schlissel
    August 4, 2008 at 3:42 am
    Look up “motion tab” in your FCP manual. That will tell you how to rotate the footage.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • David Bogie
    August 4, 2008 at 2:54 pm
    After Effects.
    bogiesan
  • Jeremy Mullen
    August 4, 2008 at 3:06 pm
    Thanks – I get that, how to actually rotate the footage. What I would like to be able to do is rotate the WINDOW. The footage doesn’t need to be changed – my output is supposed to be sideways, so that the screen can be rotated to right the figures in the image. Think of an LCD turned vertically in an exhibition venue – to see a person standing upright in such a scenario, the video needs to be prepared sideways. It’s just a pain to work on sideways stuff. Does this make sense?
  • Zach Gold
    April 13, 2011 at 7:24 pm
    Did you ever figure this out? It would be useful for me as well.
    Zach
  • Jeremy Mullen
    April 14, 2011 at 3:05 pm
    put just the windows on one monitor, rotated the monitor, and worked on the other one! A ‘hardware’ solution, since there didn’t seem to be a software one.
