Working in Linear color space confusion
When comping in Nuke we usually use Rec. 709 footage and comp in Linear color space. We can then preview in sRGB or Rec. 709 or whatever othe color space to check what it will look like.
In after effects how do we achieve the same?
You would think that:
1/ Interpret footage as Rec 709. No problem here.
2/ Set Project to Linear colorspace. But this is were the weird stuff happens. Since you have to select a color space other than linear and THEN tick linear compositing. That is the same as saying that you want composite in two different colorspaces at the same time? Thats is confusing so what is the right way of working here to composite in Linear cool space to get after effect to act the way Nuke does?
3/ Then Simulate Output -> Rec 709
Thank you in advance.
