Activity Forums Adobe After Effects Working in HD
  • Working in HD
    Posted by Jay Thompson on October 15, 2007 at 4:45 pm
    Hello everyone,
    I think it would be beneficial if there were a “sticky post” on the subject of “AE questions about working in HD”.
    Now…I just have a typical system: Ell-690 Workstation, Windows XP Pro, Dual Quad at 3.72 GHz with 2 gig of RAM. Ton of storage space. Just starting to see HD starting to flow into my workflow.
    I’m concerned about file size, what kind of HD files can AE edit and what should it not edit, what about the various hd mpg formats. What about using, and how to use proxy’s.
    Well…you get the idea. All the various things that come into play when you attempt to work in the HD universe.
    You thnk a sticky post would be helpful?
    Jay Thompson
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
    Steve Roberts replied 18 years, 11 months ago 2 Members · 1 Reply
  • Steve Roberts
    October 15, 2007 at 6:09 pm
    AE can work on comps up to 30,000 by 30,000, if I recall. So HD is no sweat for the app, as is 2K or 4K film.
    You need enough RAM to preview the number of frames you want at the comp window res you want. Do a test animation at 1280×720, 1920×1080, keep Task Manager open to see RAM usage, and see how many frames you can preview. 2GB isn’t much … you should have at least 4 GB.
    Disk speed isn’t a big issue with AE — that’s an NLE problem.
    As for file size, render a :30 spot in the two resolutions above in the Animation codec, Photo-JPEG codec, TGA sequence, PNG sequence and see how much space they take up.
    You might be in trouble if you have to render to DVCPROHD or Apple ProRes codecs, since you have a PC, and those codecs are mac-only, if I recall. You might want to consider switching over to OSX.
    AE doesn’t like importing any MPEG, including HDV (unless they’ve changed something). You should convert to another format before importing those.
    Anybody else?
