Activity Forums Adobe After Effects Working in 9×16 (Vertical)
  • Working in 9×16 (Vertical)
    Posted by Jake Abramson on March 19, 2009 at 10:43 pm
    We have a 16×9 monitor mounted vertically.
    Currently I create a 16×9 sequence (DV/DVCAM Anamorphic) and spend my entire project working on it with my head tilted at a 90 degree angle.
    Is there a way to create a vertical project that I then rotate into my final timeline for dumping to tape. I’ve tried creating a tall comp, but I get thrown with the 1.2 Pixel Aspect ratio (720×480) which only seems to be adjustable on the horizontal and not the vertical.
    Bartek Skorupa replied 17 years, 5 months ago 2 Members · 3 Replies
  • Bartek Skorupa
    March 20, 2009 at 10:32 am
    I would do it a bit differently:
    I would create “working comp” 540×720 pixels with square pixels. (9×16)
    I would do all the work using this comp, so that I wouldn’t have to tilt my head.
    When I’m happy with the result I would create “Final Comp” – 720×480 anamorphic, put my “working comp” into it, rotate it 90 degrees and render.
    Bartek Skorupa
    Warszawa, Poland
  • Jake Abramson
    March 20, 2009 at 3:35 pm
    I took your idea and modified it slightly.
    I created a square pixel 480w x 864 h (720 x 1.2 pixel aspect ratio of anamorphic).
    I then took this comp and dropped it into a standard 16×9 anamorphic comp and rotated it 90 degrees. It fit perfectly.
    Bonus item: the DV preview in AFX shows the composition correctly on my 4×3 monitor. This makes life so much easier.
  • Bartek Skorupa
    March 20, 2009 at 6:14 pm
    Jake Abramson said:
    “I created a square pixel 480w x 864 h (720 x 1.2 pixel aspect ratio of anamorphic).”
    That’s right. I made a mistake calculating the required size of the “working comp”
    Bartek Skorupa
    Warszawa, Poland
