Activity Forums Apple Final Cut Pro Working in 4:3 aspect ratio in FCP X
  • Working in 4:3 aspect ratio in FCP X
    Posted by Daniel Thomson on April 18, 2012 at 10:49 am
    I have shot all my material at 1080p 30 FPS. The final project is to be displayed on a projector with 4:3 aspect ratio. I have blocked the video to center the subject and intend to edit as 1080 30p and crop it in Compressor to 4:3 aspect ratio. The final file will play from the computer to the projector using Keynote. I would like some suggestions for alternate workflows. Can I establish a 4:3 ratio with 1080p footage in FCP X, can I display overlays for 4:3 ratio in FCPX … suggestions are welcome.
    Thanks, Dan
    Santosh Manik replied 13 years ago 5 Members · 4 Replies
  • Bill Davis
    April 18, 2012 at 5:04 pm
    Make it simpler.
    While your 1080 clips will arrive that way in the Event Browser, just create a project that has the SD 4×3 ratio you need – and when you drop the clips into it, just resize them all to fit the SD raster. (Resize one as you like, copy, drag select or select all, to highlight all your timeline clips and use Paste Effects to apply the resize to all the rest of your clips globally)
    Since the Project is SD 4×3 – the output will default to SD 4×3.
    Then you can use any of X’s Share tools to output other encodes all based on that starting point.
    Compressor’s an extra stage I don’t think you really need unless you’re trying to output something that matches a client’s specific delivery spec.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Simon Ubsdell
    April 18, 2012 at 6:09 pm
    You might want to try T. Payton’s very clever and very simple workaround for creating custom project sizes:
    https://forums.creativecow.net/readpost/344/6909
    It’s always better (for any nuber of reasons) to try and work at HD if that’s what your source material is and then scale at the end of the process.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Kevin Chavez
    August 11, 2012 at 1:06 am
    This is great!
    I will use this moving FWD. However:
    I already have about ten projects in 1280 X 720 that I want to put on an iPad for iBook author (SD?) how can I get these final projects to be in the 4:3 aspect ratio that is antive to the iPad and not have those black bars on the top and bottom.
    Also, is there any benefit to exporting in HD anyhow for an iPad? I realize the iPad 3 is “HD,” but at that size, HD doesn’t feel “mission critical” for these instructional videos for me.
    Thoughts?
  • Santosh Manik
    August 7, 2013 at 8:03 pm
    Thank U Bill,,,,,UR suggestion helped me a lot….
