Activity › Forums › Boris FX Particle Illusion › Working In 16:9 In PI
Posted by Jeff Polster on May 4, 2005 at 2:37 amTo anyone who’d know: Can you tell a newbie how to set the program up to work and deliver rendered results in 16:9? I’ve tried figuring it out but am getting nowhere.
JP
David Strelitz replied 21 years, 3 months ago 9 Members · 19 Replies -
Jonathan Decker
May 4, 2005 at 4:04 amSet your stage area to 740×480 with a pixel ratio of 1.2
gesamtkunstzwerk
Jeff Polster
May 4, 2005 at 4:39 amThanks for the quick reply. Now how does one set the pixel ratio. I see no setting for this in the program.
Sorry to be so dense.
JP
Sbilf
May 4, 2005 at 8:53 amHi all,
I have the same question, but I work in PAL, so I work in 720×576…need I to set pixel aspect ratio to 1.2 too? This mean square pixels or anamorpfhing setting?
Thank you, Max. -
Alan Mills
May 4, 2005 at 11:42 amI asked the same thing in my early days. Read the thread at
https://www.creativecow.net/forum/read_post.php?postid=109988093675433&forumid=23&archive=_2004|1|0
It helped me a lot.
Jeff Polster
May 5, 2005 at 4:22 amThanks for your trail of posts on this subject. I use Liquid
Edition 5.62 and Particle Illusion 3 and in NTSB. I’m surprised at how much work this appears to be. I’ll try to get this to work using what you’ve sent.I hope Wondertouch can make this easier in the next release. 16:9 is going to be more and more common and PI 3 is a great program. It would be a shame if it didn’t get used more because it’s hard make it work in 16:9.
Steven L. gotz
May 5, 2005 at 5:03 amWhat is hard about using square pixels? I must have missed something.
It seems to me that my only problem with 16:9 is figuring out how to get a 1920X1080 stage on a Monitor screen that is too small to do so.
I have to work at 50% or so just to fit it all in.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Bas Wolters
May 5, 2005 at 5:56 amCan you make PI work for your 4:3 projects? In NTSC a square pixel is ‘converted’ to a 0.9 ratio pixel for 4:3 projects and to a 1.2 ratio pixel for 16:9 projects. This ‘conversion’ is done by your editing program and there is no need to do this in PI.
As a comparison, digital photo cameras only use square pixels and don’t offer 0.9 or 1.2 pixel ratios. But that doesn’t stop anyone from importing photos into their videos, right?
Aharon Rabinowitz
May 5, 2005 at 11:38 amHi Everyone – I will figure this out, later today. I have a method of figuring out how the square pixel equivilent of a non-square comp. I have to go to the hospital for my dad this morning, but hopefully be back later today.
Fear not, this shouldn;t be a big deal, and probably isn;t – it just takes a little figuring out. Once you know, though, it’s no big deal.
Aharon
Aharon Rabinowitz
arabinowitz(AT)yahoo(DOT)com
http://www.allbetsareoff.com
http://www.pIllusionFusion.com
