Activity Forums Adobe Premiere Pro Working huge uncompressed footage
  • Working huge uncompressed footage
    Posted by David May on May 31, 2008 at 4:10 am
    Hi all.
    When I export my After Effects project as an uncompressed avi (bad boy is about 49gb for 8min of video), and then import the file into premiere to re-attach my audio, Im having some problems.
    More often then not, Premiere will just crash at the thought of working with such a large file. I cant preview the footage in the preview pane or, again, premiere will crash.
    Eventually I decided to not look at the footage and just export it as an MPEG2 Blu Ray so I can see what it looks like, but I stopped after 10 minutes. Premiere had rendered 80frames out of 13,000 and the eta was still going up (passed 10 hours ftw!).
    So whats the solution? Should I just export a low quality version of the footage (The original footage is HD 1080 50i @25fps), use it to make sure all my audio is lined up properly, then bring in the uncompressed and leave my pc for about 4 days?
    Any ideas or information about why this is happening would be shweet.
    Cheers
    Dave
    (I have 4gb or ram, 2.4ghz quad core, 7950gt (256mb) and 700gb of sata, i thought these specs were ok, but could the hdd be the source of my slow rendering woes)
    David May replied 18 years, 3 months ago 2 Members · 4 Replies
  • Vince Becquiot
    May 31, 2008 at 9:39 pm
    1080 uncompresed (10 bits ?) will require a serious RAID setup. Something in the likes of a 3 drives RAID 0 with a solid RAID card. If RAID 5/10, plan on spending about $500.00 on more on the card, but you could get away with a $100.00 card on RAID 0.
    I can’t tell you if that’s what’s causing the crashes, but I can tell you that you won’t be running anything above 10 frame /seconds of 10 bit HD on a single SATA drive. Write speed is even slower.
    BTW, are you running a separate drive for your media ?
    Vince
  • David May
    June 1, 2008 at 6:00 am
    Ah crap. I dont know the number of bits in the footage, but yeah, I really cant afford the RAID setup. I have the adobe installers on one 200gb sata, and the video files on a 500gb sata.
    Heres the properties of the footage taken straight from premiere
    File Size: 11.6 GB
    Image Size: 1440 x 1080
    Pixel Depth: 1440
    Frame Rate: 25.00
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 01:03:30:02
    Average Data Rate: 3.1 MB / second
    Pixel Aspect Ratio: 1.333
    So if i have 9 of these files in after effects, opened straight off the premiere save, is rendering uncompressed out of after effects so i can re-attach the audio in premiere, and then render again the best bet? I can leave my computer on for a week just to let it get through all the footage if needs be. Or will i be able to get away with rendering from after effects as BluRay (or the highest quality codec i can find…i have no idea what that would be?), attaching audio and rendering again at the same codec without getting a big quality drop?
    Hope that makes sense, let me know if any clarification is needed. I just need it to look amazing when it hits that dvd, but thats a whole nother set of questions.
    Cheers
    Dave
  • Vince Becquiot
    June 1, 2008 at 2:42 pm
    So, what will this footage be played on ?
    If you have a BluRay burner, then, it is the obious codec choice, but if it’s going to DVD, you might as well export from AE to 720×480 at a 1.2 PAR.
    You could also try using Dynamic Link instead if it’s available on the machine, that will avoid the AE render.
    Vince
  • David May
    June 2, 2008 at 7:17 am
    Its going to be on a dvd, and as im submitting it for marking for my higher school certificate, im paranoid that it looks its best. To test, i rendered it out as a nice high quality HD MPEG2 and i got heaps of interlacing. But when i used nero vision and put the video onto a dvd, interlacing disappears and everything looks great (audio also looses some low level background noise which was a bonus).
    I know it sounds silly, but i figured that if i export the final product as the highest quality HD 25fps picture i could find (doesnt make a difference if its MPEG 2bluray?), then put it onto a dvd, id retain a really great picture. Would exporting it to encore (dvd) as 720×480 at a 1.2 PAR achieve exactly the same thing? Ive got some spare dvd’s, so ill have a play around. I just really dont want to have to go through all the hassle of de-interlacing in AE.
    Dave
    (HOORAY FOR DYNAMIC LINK! Thanks for sharing that with me, its saved me alot of time and effort)
