Activity Forums Apple Final Cut Pro Legacy working 2k in FCP
  • working 2k in FCP
    Posted by Stephen Eckelberry on August 6, 2007 at 7:49 pm
    I am working on a feature film shot on 35mm. There are some simple opticals that I have to do, flops, reverses, reframes etc. I’d rather use FCP. I will scan this in at 2K and create cineon files.
    I don’t have a video card of any kind. I can buy cineon/DPX pro to import cineon files to do the work and export the stuff back out and get it scanned to film.
    Questions:
    1. I heard that FCP works in 8bit, not 16, is the quality good enough?
    2. I am working in FCP 5.1.4 (OS 10.4.10) do I need to upgrade to studio 2?
    Stephen Eckelberry replied 19 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Mike Curtis
    August 6, 2007 at 7:55 pm
    AFAIK, here’s the deal – you can work in:
    -10 bit 4:2:2 Y’CbCr
    -32 bit 4:4:4 Y’CbCr if you set it up right
    -8 bit RGB 4:4:4
    I really wouldn’t recommend FCP as the tool to fix this stuff – After Effects would be better, and there are ways to properly set it up and do batch type processing on it.
    Mike Curtis
    HD For Indies – Hi Def Filmmaking & Post for Independent Filmmakers
  • Stephen Eckelberry
    August 6, 2007 at 8:11 pm
    Probably right about working in After Effects.
    “32 bit 4:4:4 Y’CbCr if you set it up right” Can you direct me to a post on how I would do that?
    Thanks.
  • Mike Curtis
    August 6, 2007 at 8:18 pm
    I’m not aware of a post.
    I consult for a living on matters such as these if you’d like me to walk you through it.
    -mike
    Mike Curtis
  • Aaron Neitz
    August 6, 2007 at 8:41 pm
    You really should just use After Effects (or similar). FCP is such a shaky piece of software when dealing with advanced formats…. you’re setting yourself up for more problems than it’s probably worth.
    August 6, 2007 at 8:54 pm
    Thanks guys. I will hire an after effects person to do these. Are you in the LA area Mike?
  • Mike Curtis
    August 6, 2007 at 9:05 pm
    Nope, sorry, Austin, TX. But I could walk you through it over the phone.
    Mike Curtis
    August 6, 2007 at 9:57 pm
    Thanks for the offer. I have a feeling that I better not open up that can of worms, and simply hire someone for a couple of days to work AE.
