Activity Forums Blackmagic Design workgroup hub and downconvert
  • workgroup hub and downconvert
    Posted by Baz Leffler on October 18, 2008 at 5:39 am
    Does anyone here know how to set the output of the workgroup hubs downconverter to NOT put letterboxing on the output?
    Baz
    What would I do without the ‘UNDO’ button!!!!
    Chris Pearse replied 17 years, 10 months ago 2 Members · 1 Reply
  • Chris Pearse
    October 20, 2008 at 3:09 pm
    Hi Baz,
    Unfortunately there is only one type of downscaling available on the Workgroup Videohub. The downconversion feature on the Videohub is more for monitoring purposes than anything else.
    Should you be using one of the Decklink cards that allows downconversion on output, such as the Decklink HD Extreme 2, you can set it to downconvert in either letterbox or anamorphic for SD. This can then be sent into the Videohub.
    Chris Pearse
    Technical Support Consultant
    Blackmagic Design EMEA
