Activity Forums Adobe Premiere Pro workflows with premiere pro and after effects
  • workflows with premiere pro and after effects
    Posted by Accountclosed on October 21, 2005 at 8:26 am
    hello all. i edit in premiere and when a scene needs effects or something undoable in premiere, i do it in afterefects, exporting and importing uncompressed avis.
    recently on adobe’s site, i read that in the cross country road race movie they cut the film in premiere and then imported the project into after effects and applied effects there.
    i was wondering if anyone had any thoughts or wanted to share their workflow. the flow from adobes site was hard for me to grasp, since often times you dont know how the scene is going to cut until u apply the effects.
    i work usually with panasonic 24p footage. thanks!
    Steven L. gotz replied 20 years, 10 months ago 2 Members · 3 Replies
  • Steven L. gotz
    October 21, 2005 at 2:31 pm
    I usually cut in Premiere Pro. Then the smaller sections that require After Effects get copied from the Premiere Pro timeline to the After Effects timeline. I perform the task in AE and then export to the same exact codec I use in Premiere Pro. Which is either DV-AVI or the Cineform codec depending on if I am editing SD or HDV.
    Why not use uncompressed? Because Premiere Pro is going to have to compress it anyway while rendering. So I might as well only render once – in AE. Since I do my titles in AE, there is little chance that rendering in Premiere Pro will be necessary if I bring it back in properly.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Accountclosed
    October 21, 2005 at 4:50 pm
    Hey Steve, have you ever worked with 24p footage? my flow is similar to urs except with the compression, however i’ve been having a hard time getting the timecode to match up. thoughts?
  • Steven L. gotz
    October 21, 2005 at 6:21 pm
    Sorry, but I have no experience with 24p.
    Steven
