Activity › Forums › Adobe After Effects › Workflow with Prores and PC
  • Ben G unguren
    February 4, 2012 at 5:07 am
    I think they just need to install the latest free version of quicktime player. It should be able to play prores-encoded files. Or do an encode of everything with the Animation codec, or even as an image sequence (the most reliable method IMO, but you’ll have to re-encode everything). But the QT should really work, esp if you’re using AE on both machines!
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Michael Szalapski
    February 6, 2012 at 7:43 pm
    You can get the ProRes codec for PC’s from Apple. You can’t render in ProRes from a PC, but you will be able to read it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
