Activity Forums Adobe After Effects Workflow with basic editing between AE and Premiere
  • Workflow with basic editing between AE and Premiere
    Posted by Jake Rose on December 3, 2014 at 6:07 pm
    I am working on a project in After Effects that started as a simple video in Premiere. I did the basic edit in Premiere, highlighted the whole project, then right clicked and hit “replace with AE comp”
    Now, after creating some graphics, I want to lengthen one of the clips. If I make it longer in AE, than the audio gets off synch back in Premiere. I can’t lengthen in Premiere, because the sequence is already that pink “comp” bar.
    What’s the best (pro) way to do this without a ton of extra work re-synching, etc.?
    Michael Szalapski replied 11 years, 9 months ago 3 Members · 3 Replies
  • Jake Rose
    December 3, 2014 at 7:01 pm
    You’re making me angry! Ha ha ha, was afraid some one would say that. Okay, fair enough.
    Maybe in future Adobe updates, individual clips that have been grouped into an AE comp can still be “backwards recognized” (for lack of a better term) in Premiere… although I guess at that point I am basically suggesting that Premiere and AE should just be merged into one program, which I wouldn’t doubt that we’ll see in the next decade.
  • Walter Soyka
    December 3, 2014 at 8:58 pm
    [Dave LaRonde] “You’ve just run into a basic principle of going between PP & AE: if you start the edit in PP, make sure you have edit lock — i.e. no further edit changes — before you go to AE.”
    Or work on individual shots instead of the entire timeline at once.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Michael Szalapski
    December 3, 2014 at 9:59 pm
    I’m with Walter. If you don’t have edit lock, edit the clips individually.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
