Activity Forums Blackmagic Design workflow to convert DVCPROHD, 1080i to DVCPROHD 720P
  • workflow to convert DVCPROHD, 1080i to DVCPROHD 720P
    Posted by M Brown on November 19, 2005 at 12:31 pm
    Anyone have a good solution for converting DVCPROHD 1080i video to 720P? Also what is the best universal QT codec for AVID/FCP and the other brands “X” so we can send QT clips to clients that wil lwork on their systems?
    thx..mason brown
    M Brown replied 20 years, 9 months ago 2 Members · 2 Replies
  • Luke Maslen
    November 21, 2005 at 5:54 am
    Hi Mason,
    This is a good but frustrating question as there are lots of TV’s which can take a 1080i signal and display it as 720p and yet I cannot find an SDI convertor which does this. I had a quick look at the convertors in decks and also couldn’t find a format convertor to do this but maybe I missed something and someone else in this forum will report it. Can you tell me what workflow you have in mind where 1080i to 720p conversion would be helpful?
    The best universal QT format is uncompressed 2vuy for 8-bit or uncompressed v210 for 10-bit. Uncompressed is essentially a raw format and should be able to be ready by any QT-savvy application. Final Cut Pro HD includes Apple Uncompressed 4:2:2 codecs and we also have our own, both of which will enable you to open movies in the 2vuy 8-bit and v210 10-bit formats. This is the nice thing about using open standards in that it makes it easy to move files between systems regardless of the software or hardware being used.
    Regards,
    Luke Maslen
    Blackmagic Design
  • M Brown
    November 21, 2005 at 11:33 pm
    Luke,
    Thanks for the fast reply and terrific information. I’m using the latest version of FCP 5 and your BM codes with a BM HD link card.
    When I try to export a clip from 1080i DVCPROHD to the BM 8 bit (2VUY), I’m getting a dialogue box that tells me it’s medium quality. Is that OK?…can I get “Best” quality? Same thing happens if I go to the botttom of the list and select, Uncompressed 8 bit 4:2:2.
    Should I be using a custom size 1280 X 720? or wil lautomaic cover that?
    thx..Mason
