Activity › Forums › Apple Final Cut Pro Legacy › Workflow suggestion for 24frames to 25 frame edl for then Scanning in2K
  • Workflow suggestion for 24frames to 25 frame edl for then Scanning in2K
    Posted by Mody on October 18, 2006 at 2:18 pm
    Hello friends
    Would love to have a solution to the problem I am facing in setting my workflow,
    We have a FCP, Multibridge Extreme and Huge arrays ,
    We have create a project for film on blackmagic pal 8bit with the setting of 24fps all setting of timeline, capture preset, device control are on 24fps. We have captured material which is also on 24fps
    now my timeline setting is on 24fps as per my setting. After editing this timeline I want a 25 frame edl without changing my timecode of footage or timeline for film scanning. How do I get the edl, what kind of setting has to be done or is there any other way to get the edl.
    I have tried making the the project on DvPal 24@25 and copied my timeline to its timeline with the setting of the timeline on 25fps. After taking out the edl I tried matching the timecode of both the timeline but it doesn
    Jerry Hofmann replied 19 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 18, 2006 at 2:23 pm
    I don’t think there’s a way to add a frame per second, then expect the TC to remain the same… it doesn’t compute…
    Why do you need a 25 fps edl? film is usually 24fps..?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
