Activity Forums Apple Final Cut Pro Legacy Workflow recommendation needed
  • Workflow recommendation needed
    Posted by Matt Dufilho on August 10, 2011 at 8:26 pm
    I would appreciate any critique/advice on my planned workflow for an upcoming project:
    Integrating architectural animation with interviews/talking head shots, shot in 720p30.
    Animation will be delivered as image sequences from 3DSMax (3DS Max project settings: 720×480 0.9PAR Anamorphic). I will put these trough After Effects and render out ProRes files of same res. Unable to get HD renders from animators due to render times…they have to stay SD.
    Delivery: online widescreen video; widescreen DVD
    PLANNED WORKFLOW:
    Edit interview/talking head segments natively in 720p. Design motion graphics in 720p.
    Add animation to 720×480 0.9PAR Anamorphic timeline. Paste edited interview segments. Paste motion graphics.
    Anything I could do differently?
    Could I ask for anything different resolution from my animator to avoid non-square pixels in my edit?
    If nothing else, I appreciate any advice.
    -Matt Dufilho
    Jerry Hofmann replied 15 years, 1 month ago 2 Members · 3 Replies
  • Jerry Hofmann
    August 10, 2011 at 8:44 pm
    What’s the delivery format to be? A web stream or a DVD or HD broadcast or?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Matt Dufilho
    August 10, 2011 at 8:56 pm
    online widescreen and widescreen DVD
  • Jerry Hofmann
    August 10, 2011 at 9:56 pm
    You might find then that working in an SD 16:9 sequence may look better in the end because you’re not up razzing the SD to HD… try it both ways and then compress to the deliverables with say, just a couple of shots using the SD and HD footage in a short sequence. See if you notice a difference between the two in the end.
    Jerry
    Current DVD:
