Activity Forums Apple Final Cut Pro Legacy Workflow questions for 200+ hours of h.264 and ACVHD
  • Workflow questions for 200+ hours of h.264 and ACVHD
    Posted by Khashyar Darvich on April 15, 2011 at 8:15 pm
    Hello Everyone,
    I just returned from a 3 month overseas documentary film production trip that resulted in over 200 hours of Canon DSLR video (h.264) and ACVHD video files (from a Panasonic TM700).
    I know that the recommended procedure is to convert both the h.264 and ACVHD to Prores 422 for editing.
    I also understand that if we convert these files to Prores 422, that the resulting new Prores files will be 4 to 5 times larger in file size than the originals.
    Since we accumulated about 5 TBs of footage during the production, if we converted all of the original camera files, we might end up with 25 TBs of Prores 422 footage to edit with (about 12 two TB drives).
    Thank you for offering your suggestions regarding how to make the file conversion process as quick and apace-efficient as possible.
    Here are a couple of specific questions that I would appreciate help with:
    1) Is there an alternative format other than Prores 422 to covert files for a kind of “offline” edit? On this portion of the edit, we are using a G5 Quad core and FCP 6.06, which plays converted Prores 422 files fine. But, in FCP 6.06, there is no Prores LT option.
    2) What is the most efficient way to name reels so that we can best organize the clips? Show we use shooting date as the reel numbers/names?
    3) What is the quickest way to convert the production files to Prores 422 files? I know compressor can do it. For the ACVHD files, I believe that we are going to use Clipwrap.
    4) I tried to use the Canon “movie” DSLR plugin for Final Cut (which incorporate a date stamp into the timecode, and although it installed fine without a report of any erros, Log and Transfer still does not recognize the Canon files after the plugin install. Is there a way to use the plugin that I am not aware of?
    5) How many hours would you guess that this conversion process will take for 200+ hours of footage? (I’m almost afraid to ask 🙂 ).
    Thank you for your help and suggestions.
    Steve Eisen replied 15 years, 4 months ago 6 Members · 19 Replies
  • 19 Replies
  • David Roth weiss
    April 15, 2011 at 8:44 pm
    [Khashyar Darvich] “1) Is there an alternative format other than Prores 422 to covert files for a kind of “offline” edit? On this portion of the edit, we are using a G5 Quad core and FCP 6.06, which plays converted Prores 422 files fine. But, in FCP 6.06, there is no Prores LT option.”
    This question is asked a lot, and it’s a question that is “il-formed.” Any answer you receive to that question will invariably ignore the bigger issue, which is that it is inevitable that you will have to pay the piper now, or pay later.
    Since you went out in the field and acquired 200 hours of footage without knowing the answers to these questions in advance, and since you’ve already suggested that Log & Transfer isn’t working as expected, realize that any offline you create will almost inevitably be a bitch to deal with when it comes to your online at hi-res later in the process. So, while you can in fact save yourself some hard drive space, what you gain compared to what you will lose in the process will be inconsequential by comparison.
    In other words, bite the bullet, transcode to ProRes 422 and resist the temptation to cheap out on hard drive storage, which can be had these days for $60 to $70 per Terabyte, all over.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Khashyar Darvich
    April 15, 2011 at 9:23 pm
    Thank you for your thoughts and feedback, David.
    I understand that you are saying that it I will save time, confusion and frustration to transcode all of the footage now.
    The cost of the hard drives aside (which, will probably be double since it is probably smart to have a backup of all of the converted footage as well), how much time do you think it will take to transcode 200+ hours of footage to Prores 422?
    We will begin ASAP with the transcoding 🙂
    Khashyar
  • Khashyar Darvich
    April 15, 2011 at 9:29 pm
    Another issue is…
    If I have 20-25 GB of converted footage, how do I access all of the drives during editing?
    Do I build an array?
    Do I choose footage for the rough cut and then save only the files I need to a separate drive?
    What do you suggest?
    Thank you again.
  • Khashyar Darvich
    April 15, 2011 at 9:30 pm
    Hi Dave,
    I do appreciate yours and his advice.
    Thank you.
  • Everest Mokaeff
    April 15, 2011 at 9:59 pm
    It’s kind of belated question you ask. Actually all of them. How you organize your workflow depends upon too many factors, let alone financial issue. The most reasonable approach is hire specialist who dealt with such problems before and is fully aware of the needs of your production. Again, depending on your needs there are lots of quite affordable solutions that let you do preliminary work of logging clips and preview without conversion. If it fits your pipeline why not to utilize it. If raid is something off limits to you consider renting edit suite with enough capacity to store your material.
    Everest Mokaeff
    http://www.mokaeff.com
  • Khashyar Darvich
    April 15, 2011 at 10:17 pm
    Thanks for your thoughts, Everest.
    I producer and direct feature documentary films, the last one an international theatrical doc, and this is the first time that I have worked with footage from Canons or ACVHD.
    So, I thought that Final Cut Pro could edit the footage natively, and did not realize they needed to be converted.
    This is why these new questions have arisen for me.
    Thank you for your thoughts about how we can most efficiently move ahead with editing at this stage.
    If we feel that we need to hire a specialist later, then we will. Thank you for that suggestion.
  • David Roth weiss
    April 15, 2011 at 10:29 pm
    [Khashyar Darvich] “how much time do you think it will take to transcode 200+ hours of footage to Prores 422?
    The answer really depends on the speed of your computer and how you do the transcode. Compressor can utilize multi-core, multithreaded computers to do the job faster than realtime, and the faster the procs and more cores it has, the faster the transcoding process.
    Do a few hours and time it on your computer, then extrapolate from there…
    Once you really get going on the job, I would advise that you create a Compressor droplet and do batches of files at one time, with reboots in between, to clear RAM and to make sure your computer encodes at it’s fastest.
    David Roth Weiss
    Los Angeles
  • Khashyar Darvich
    April 16, 2011 at 1:58 am
    Thank you for your suggestions, David, and for sharing your expertise.
    I have begun to transcode the ACVHD footage via Clipwrap, and it is taking a long time.
    It is better to begin this now than later 🙂
    Do you know off-hand whether Compressor can transcode ACVHD files?
    Thank you again.
  • Jeremy Garchow
    April 16, 2011 at 2:40 am
    I have no idea what your budget is.
    30TB of storage is not going to be cheap when assembled in a useful manner. A “loose” 30TB made up of a bunch of drives is going to be downright unmanageable and might as well be impossible.
    My suggestion? First, buy fcp7. No questions.
    Then, Buy grinder which will allow a transcode of your dslr to ProRes Proxy with burn in. I think your AVCHD footage should come in through log and transfer.
    200 hours of 1080p23.976 ProRes proxy is just under 4TB.
    Edit. Edit. And edit.
    At the end, you can conform your final dslr shots with Grinder, and rebatch your avc with l&t.
    Make sure you test this or any workflow. You have no tc, be careful.
  • Zane Barker
    April 16, 2011 at 3:24 am
    “On this portion of the edit, we are using a G5 Quad core”
    “how much time do you think it will take to transcode 200+ hours of footage to Prores 422”
    With a G5 it gong to take a really really long time.
    If there is any possible way you could move to a MacPro then do it. This would also give you the ability to move to FCP 7 and have access to the newer forms of ProRes.
    **Hindsight is always 1080p**
