Activity Forums Apple Final Cut Pro Legacy Workflow question: On-set shot logs to FCP project bins
  • Workflow question: On-set shot logs to FCP project bins
    Posted by Chris Petrauskas on December 11, 2009 at 10:25 pm
    Hello,
    I’m shortly taking delivery of two JVC HM100s for producing a studio-based educational series.
    Since the HM100’s produce native QT files I’ll be able to bypass Log & Capture and drop my files straight into a bin.
    My concern is with how can I get my on-set shot log info married to the files in the FCP bins.
    I can have access to FCP while on set.
    I’ve been thinking of a hack that goes like this:
    * I set-up my media folders (camera_A & camera_B) and populate then with a set of sequentially-named QT dummy files (1-sec slugs).
    * I drop the dummy files into their respective bins in my FCP project.
    * During the shoot I edit the appropriate info under Item Properties > Logging for each respective shot (Good, Description, Log note, etc.).
    * Post-shoot, I batch-rename the camera files to match the dummy files and move them into place of the dummy files.
    * I relink the media (actually, just happens with the same names.)
    I’ve tested it a few times and it seems to do what I want:
    The log info that is FCP-centric stays in the project bin and the technical attributes of the files TC, duration, etc. seem to update properly.
    So, does this seem like a reasonable workflow for my circumstances or am I way out in left field? I’m not looking to reinvent the wheel here.
    Chris
    Chris Petrauskas replied 16 years, 8 months ago 1 Member · 1 Reply
  • Chris Petrauskas
    December 15, 2009 at 1:10 am
    If not the JVC cameras, could anyone recommend another solid state recording workflow that might apply?
    I’ve looked at P2 and XDCAM workflows but there are usually format-specific utilities to use.
    C.
