(workflow) Optimizing embedded After Effects animations in Premiere PRo
Hi all- I’ve searched high and low and haven’t found the optimial solution for my new project template structure/workflow.
Here’s what the workflow I’m looking for:
– Create new Premiere Pro CS6 project from template
– New project has intro/outtro embedded
– Can create new animated text overlays from Premiere Pro (using After Effects template embedded in premiere pro template)In the end, I’d like to have an efficient way to create new video projects in Premiere Pro CS6 that leverage a pre-built intro/outtro, and also make it easy for me to add new animated text overlays (with unique/new text) without having to navigate between Premiere Pro CS6 and After Effects CS6 a whole bunch of times.
I’ve figured out how to do the text animations, and how to import into Premiere Pro, but I don’t see a way to do new variations of my text composition without extra work in After Effects.
Possible? Would love to hear your suggestions. How do you all structure and work with these kinds of projects in CS6? Thanks for your time.
