Activity Forums Adobe After Effects Workflow: JavaScript => (Illustrator) => After Effects
  • Workflow: JavaScript => (Illustrator) => After Effects
    Posted by Daniel Lap on January 28, 2013 at 2:39 pm
    Background
    I have coded a JavaScript data visualization that outputs SVG elements that are animated – in the browser – based on their data attributes. I would now like to produce a video (with a little bit of 3D and motion blur) of a set of these animations using After Effects.
    Manuscript
    1. 200 (vector) circles on a straight line.
    2. Camera pans across these.
    3. Circles are animated (color, radius, x and y of the circles) while camera moves
    I’d preferably reuse the code for the animations but I am not sure how to go about.
    Are any of these workflows applicable? And in that case, which one is better?
    1. “Illustrator layers to keyframes”
    I paste the SVG elements generated in the browser into Illustrator and then into AE.
    Then I paste the same set of layers on another keyframe and somehow AE can figure out the tween …
    2. “JavaScript in After Effects”
    I use the code to somehow script the animation in After Effects … (Can I use external JS libs when scripting AE?)
    3. “A much better alternative …”
    Daniel Lap replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
