Activity Forums Avid Media Composer Workflow HDCAM to QT & DVD delivery
  • Workflow HDCAM to QT & DVD delivery
    Posted by Christian Hart on September 8, 2010 at 1:19 pm
    Hello there,
    I’d appreciate it if anyone can point out any glaring holes in the following workflow…
    I’m about to start a project shot on HDCAM but destined for
    a few different non-broadcast outputs, primarily:
    1. SD DVD (Pal)
    2. Quicktimes for playing from hard disks for some on site installation videos.
    I would usually use FCP for a project like this, but on this occasion I have to use MC4 (on an intel 2x 2.66 dualcore with the media on a FW800 drive.)
    My plan is to get the rushes captured DNxHD 145 and without an online use compressor or similar to make the SD DVDs and quicktimes.
    There’s a possibility we might be asked to supply HD versions later on..
    Any thoughts?
    Much obliged.
    Michael Phillips replied 16 years ago 2 Members · 3 Replies
  • Michael Phillips
    September 8, 2010 at 8:42 pm
    Process is pretty straightforward. Once edit is complete, render your timeline and export a QT reference for use with Compressor or encoding application of your choice. Just remember that digital video for broadcast assumes 16-235 RGB for black and white levels and compressor expects 0-255. If you export out as REC709, Compressor will lift the blacks since it assumes (makes an ass of u and me) that it is 0-255.
    If you export out as RGB, Media Composer will create full range 0-255 as part of the QT ref process so that if makes up for the inability to address that in Compressor.
    Michael
    Michael Phillips
  • Christian Hart
    September 8, 2010 at 11:21 pm
    Thanks for the reassurance Michael,
    Yes the RGB/ 709 issue – remember that confusing the hell out of me when i first started using FCP
    (I still don’t understand it fully, i remember doing some tests once – DVDs looked the same weather i started with a 709 export or an RGB export…)
    I was more worried about the DNxHD codecs causing me any issues when it comes to delivery – i’m used to more of an offline/online process when using avid – but i guess i don’t see why it would – even if i have to err… deliver something like h.264 quicktimes..
  • Michael Phillips
    September 8, 2010 at 11:30 pm
    DNxHD145 will serve you just fine for those deliverables as well as a potential broadcast down the road.
    Michael
    Michael Phillips
