Activity Forums Apple Final Cut Pro Legacy Workflow from Avid and Premiere to FCP
  • Workflow from Avid and Premiere to FCP
    Posted by Danny Skarka on January 26, 2012 at 5:32 am
    Our facility gets video from a variety of sources, but we require Apple Pro Res 422/1920×1080/29.97/48Khz codec due to our KiPro play outs.
    What is the best output format from Avid and Premiere that will reformat well in FCP?
    Thank you all…
    Dennis Radeke replied 14 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    January 26, 2012 at 7:29 am
    [Danny Skarka] “What is the best output format from Avid”
    DNxHD QUicktimes. YOu then need to download the DNxHD codecs from Avid.com…and then you can convert the files to ProRes. Or, have the people who use Avid do it…if they can. Warning, there is a gamma shift issue between these two codecs.
    [Danny Skarka] ” and Premiere “
    Premiere doesn’t have a codec. I’d have them render out as PhotoJpeg, and then you convert to ProRes.
    Shane
    Little Frog Post
  • Dennis Radeke
    January 28, 2012 at 11:58 am
    [Danny Skarka] “What is the best output format from Avid and Premiere that will reformat well in FCP?”
    For Premiere Pro, put the ProRes codec on the Premiere box ala $50 Compressor (if it’s a Mac) and then you can create and render out a ProRes preset.
    Failing that, there’s also Animation and AVC-I 100 that would work as DI’s to ProRes.
