Activity Forums Compression Techniques Workflow / format recommendation
  • Workflow / format recommendation
    Posted by Shawn Hughes on March 27, 2013 at 11:01 pm
    I know this has been discussed ad nauseum, but I’ve researched until I got a headache.
    I am trying to build a digital out, but for now, what I have is what I am going to use.
    I am running a BetaCam SX. Composite out, XLR > unbalanced audio
    Capture card is a SinoVideo PCI 2309 Proteus (7134 WDM)
    The card gives me the following options:
    YUY2
    UYVY
    RGB 555 (16 bit)
    RGB 24
    RGB 32
    YVU9
    I420
    Video Decoder
    NTSC_M
    NTSC_M_J
    NTSC_433
    Which will give me the best footage to work with? I don’t know what the output will be, and the computer I’m using is ancient.
    Shawn
    Craig Seeman replied 13 years, 5 months ago 3 Members · 4 Replies
  • Craig Seeman
    March 28, 2013 at 1:42 am
    It may well depend on what NLE you’re going to use.
    Wasn’t that a TV capture card?
    You can buy a Blackmagic Intensity Pro card with analog breakout cables really cheap.
    You can buy a Blackmagic Studio card with SDI in. They’re not that expensive.
  • Jeff Greenberg
    March 28, 2013 at 2:00 pm
    Shawn, on the scale of 1-10 where I know what I’m talking about, I’d rate this a 5. I’ve never seen this equipment before and google searching is getting me anywhere.
    I’d pick: YUY2 as thats likely YUV colorspace with 2 samples for the Chroma (422). None of the rest of them would be a good match for betacam tapes.
    I think the decoder is to decode analog television streams.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Shawn Hughes
    March 28, 2013 at 11:00 pm
    Jeff – That (decoder) makes perfect sense now. Useless..lol
    Thanks for the suggestion. I’ll test that shortly.
    And, yeah, it’s a crap card. It is a P34, but it says “Easy Your Life” on the top. Nothing else… LOL
    Craig – Thank you for the suggestions. I don’t own a desktop, and what my intent is portable ingest for spot news so I can upload to Ustream. Plus, I want to hold off purchasing until I can see if I can get the digital component connector figured out.
    Thanks again!
    Shawn
  • Craig Seeman
    March 29, 2013 at 12:43 am
    [Shawn Hughes] “my intent is portable ingest for spot news so I can upload to Ustream.”
    Ustream? You want to live stream news?
    I’d recommend either a MacBookPro or an Asus laptop with Thunderbolt. Get a Blackmagic UltraStudio Mini Recorder (HDMI and HD-SDI) Or UlstraStudio Express (adds analog breakout). You’ll be able to record and stream live. Just add streaming software.
