Workflow for whiteboard animation shot in Red Raw 5K
Editing a new whiteboard animation. It has been shot in Red 5K and I got raw native files plus progress files 3840×2160 plus prores files at 1920×1080.
What’s the most robust workflow with Premiere?
All the selected shots will need to be sped up at around 600+fps. Is Premiere retiming effect much better than FCP7 (no optical flow there)?
Can Premiere CS6 and after effects Cs6 handle well Raw footage for retiming and editing?
if the Raw files slow down the process I am hoping to work with the 3840×2160 files, zooming in and reframing at certain times and still get a good looking 1080 web deliverable.
As much as possible I want to most of the work in Premiere cs6 because adding AE may slow down the process unless the quality is noticeably better.
Any suggestions?
Thank you!Mabel Valdiviezo
Producer / Editor
415-335-3143
