Activity › Forums › Panasonic Cameras › Workflow for Using PX270 AVC-LongG Footage IN FCPX?
Chris King replied 11 years, 7 months ago 6 Members · 24 Replies
Jorgen Gustafson
November 24, 2014 at 12:49 pmI’m using Intra100 for post, but sometimes I’m just shoting a long show and it’s going right to archive without any post…and the I use Long-G. Not even apps like MXF Converter or MXF Wrapper Pro can read the Panasonic Long-G. The strange thing is that Compressor swallow this codec and I can re-pack it to “ordinary” H.264/.mov for archiving :-D. That’s strange…Compressor takes it, but no other app!
I really hope that they fix this – a Panasonic AJ-PX270 gets much more useful if you can use all codecs/settings – it gets more versatile.(I just notised that QT7pro can play this MXF files with Long-G – maybe that’s why also Compressor can take them)
David Schumacher
November 24, 2014 at 1:17 pmThis is amazing to learn! Which version of Compressor are you using? How do you bring the footage into compressor (ie all the different folders, etc)?
Jorgen Gustafson
November 24, 2014 at 5:55 pmI just drop the MXF file into Compressor.
(I have a plug named “MXFImporter.component” in the QuickTime plugin folder. If this plug is Apple standard – or if I have installed it when installing all those apps I’ve tried past years – I don’t know)
David Schumacher
November 25, 2014 at 5:02 amUnfortunately I tried dropping a couple of AVC-G files into Compressor but as soon as I try dropping the output setting on them Compressor crashes. I have MXFImporter.component installed too.
Which version of Compressor are you running and which OS?
Jorgen Gustafson
November 25, 2014 at 5:23 pmI have the latest of everything…always :-).
My succes must be ’cause of the MXFImporter.component and I now know where I got it from – it’s from Hamburg Pro Media. I have MXF4mac installed and the QT plug makes my Compressor also like MXF – even if it’s Panasonic Long-G codec inside 🙂 -
Tony Peck
December 3, 2014 at 1:21 amIt looks like apple just added AVC-Long Gop support. I have not tried it yet. Hopefully it works well.
Jorgen Gustafson
December 3, 2014 at 6:19 pmNope. Doesn’t work. Updated to FCPX 10.1.4 and Pro Video Formats 2.0 software update – still can’t import an MXF file with Panasonic LongG codec: “None of the selected files or folders can be imported. Change the selection and try again.”
Sad bad job, Apple. You can do better than this.
I have reported it. One of the main things about this update was to support MXF LongG – Apple is bragging about it – and just this specific thing is NOT working. What can I say? Don’t they even test the updates themself? Maybe they just dp theoretical checks – reading the code – actually not trying to import anything in real life? 😀 -
Tony Peck
December 3, 2014 at 10:31 pmI just did a quick test and it worked great in FCPX. I had no problems at all. I only shot 5 minutes of video. I I’m going to do another test with longer footage.
Jorgen Gustafson
December 4, 2014 at 6:43 amI’m comunicating with Apple now – they want to know what camera (AJ-PX270EJ) I used to create the file. The file is alson not on card – it’s copied from card to hard disk. The drama goes on. 🙂
Jorgen Gustafson
December 4, 2014 at 1:44 pmQuickTime 7 Pro plays the file, but something is wrong:
QT says the file is 5,3 GB – it is not…it’s 238 MB in Finder and that’s right (it’s just one minute of 720p50).
QT says it plays with 746 Mbit/s!!! That’s also totally crazy – it’s a LongG file at 25 Mbit/s.
So – I have to make another file for testing, but the cam is not here now. And it’s scary if the camera make corrupted files (I have latest firmware).
I will do different files, maybe it’s just 720p50 that is a strange bastard.
I’ll be back.
