Activity Forums Apple Final Cut Pro Legacy Workflow for two editors
  • Workflow for two editors
    Posted by James Ratnarajah on July 1, 2010 at 12:07 pm
    Hey guys.
    I’m sorry if this is on the wrong section, but couldn’t see where else to put it.
    My partner and I film using a Canon 7D and edit on final cut pro. We are trying to figure out a way of collaborating, when editing, from two locations. Say for example I am editing one day and then my partner wants to pick up where I left off on the next day, from his place. At first I thought Final Cut Server would serve this purpose but then found it’s not exactly what we’re looking for.
    The other method I was thinking was to use an external hard drive to edit from and just exchange the drive, so all render files and media are present and correct. However this seems a bit messy.
    Can you guys offer up suggestions on what workflows you have seen work, or think would work?
    Your help would be greatly appreciated. Thanks in advance!
    James
    James Ratnarajah replied 16 years, 2 months ago 2 Members · 4 Replies
  • Rafael Amador
    July 1, 2010 at 1:23 pm
    Hi James,
    Two HDs with the same name and the same file structure.
    You only need to interchange the Project files.
    rafael
    http://www.nagavideo.com
  • James Ratnarajah
    July 1, 2010 at 1:29 pm
    Hi Rafael.
    Thanks for your response. So if I understand you correctly we would ingest and transcode footage on a HD and setup a Final Cut Project. Clone that HD, so we’d have one each.
    If I do an edit I would send my partner my project file and he would just overwrite the one he has an open the project file?
    Is this correct? If so that’s cool.
    James
    When you have eliminated the impossible, whatever remains, however improbable, must be the truth?
  • Rafael Amador
    July 1, 2010 at 2:39 pm
    Right.
    If the media has the the same path in both HDs you will never need to Reconnect Media.
    FC will only miss the renders files if the project haven’t been rendered in both systems.
    rafael
  • James Ratnarajah
    July 2, 2010 at 2:32 pm
    Got it! Will give it a few tests and see. Thanks for your help.
    James
