Activity › Forums › VEGAS Pro › workflow for mixing a feature
  • workflow for mixing a feature
    Posted by Charlesdem on September 24, 2005 at 1:19 am
    Hi –
    I was interested in comparing how people use Vegas to mix films. I’ve just started work on a feature and here’s how I’ve gone about it so far:
    Client brought me OMFs of every track from Final Cut, each one an hour and 20 minutes. This totalled 12 OMF files.
    Client also provided aif files of each track for volume and mix reference.
    Client provided me with one quicktime movie of the whole film with a scratch mix.
    I used EDL Convert to process the OMFs and then opened the .txt files one after the other into the same vegas project and put them all on separate tracks, restoring the 12 distinct tracks. I then added the quicktime, converted it to .avi and dumped the quicktime. All of this went flawlessly.
    I have the project on an internal drive and I have my extensive SFX library on an external USB 2 drive with the Media Manager linked to it. All of my SFX is tagged for use with MM.
    As I started to go through the whole project to spot check and do minor cleaning of transitions, I realized it was going to be too much to do all of this in one project so I figured I would separate the movie into scenes and then re-import them later as mixed scenes as nested veg files. So I went through the project to trim the scenes and save as individual scenes and worked on them that way. The only tricky part is going to be mixing the transitions from scene to scene where things overlap. But the ability to nest the audio in one master version to watch through and process is great.
    This makes me think: maybe in a future version it would be nice to be able to separate nested audio into separate buses, if they exist in the project so one could retain “stems” of SFX, Dialog, etc for final mastering.
    anyway, I’m wondering how differnt/similar this is to how others go aboutt his. I’d love to hear about other people’s workflow ideas, especially with how complex a project like this can be with SFX, plugins, automations, envelopes, etc.
    looking forward to hearing from you.
    Charles.
    Gary Kleiner replied 21 years ago 2 Members · 1 Reply
  • Gary Kleiner
    September 24, 2005 at 11:31 pm
    Soiunds like you’ve got it all working pretty well. I agree that the one track of audio in a nested veg is somewhat limiting. You could always reassemble your audio tracks in the new project with cut and paste (except the track FX).
    Gary
