Activity Forums DaVinci Resolve Workflow for low budget feature
  • Workflow for low budget feature
    Posted by Brian Breheny on October 18, 2011 at 10:31 pm
    Hi
    I have recently worked through post production from data capture and could never find a workflow that worked for me so this is what we did if its a help to anyone!
    WORKFLOW FOR LOW BUDGET DIGITAL FEATURE FILM
    DIGITAL CAPTURE ON RED MX @4.5K (FLAT SCOPE FOR 1: 235) 24FPS 500 ASA, BALANCED TO DAYLIGHT
    RD3 DATA AND WAV 16BIT AUDIO COPIED TO 2 X HARDRIVES AND MACBOOK-PRO
    DATA TO LACIE RUGGED SHUTTLE DRIVES (ON SET)
    RED ROCKET TRANSCODES TO PRO-RES 4444 FOR FCP (IN EDIT SUITE)
    RD3 COPIED TO G DRIVE (MAIN COPY DRIVE) AND 2 BACK-UPS VIA MAC TOWER
    AUDIO WAV FILES SYNC WITH PICTURE @24FPS FOR EDITOR
    PICTURE EDIT ON 5 REELS TO LOCK OFF WITH TEMP VFX , TITLES, SCORE AND EFFECTS
    EXPORT MOV REELS AND OMF FILES TO SOUND EDITORS (7 TRACKS )
    EDL AND SELECT RD3 FILES FROM G DRIVE INTO DA VINCI RESOLVE FOR COMPILE @ 24FPS
    TITLES MADE WITH MOTION
    COLOUR GRADING IN REELS AND IMPORT VFX PLATES AND TITLES
    SOUND MIXED TO 5.1 SURROUND
    RENDER OUT DPX FILES FOR MASTER REELS AND DCP BUILD IN OPEN DCP FOR TEST SCREENINGS
    DPX AND WAV FILES TO LAB FOR DCP WITH KDM ENCRYPTION BUILD TO COMPLETION
    DVD SCREENERS IN SD AND BLU-RAY FOR DISTRIBUTORS
    We are really pleased with results but it was a big process
    Sorry for All caps ,its copied off a paper Im putting toogether
    thanks
    Brian Breheny replied 14 years, 11 months ago 2 Members · 2 Replies
  • Kevin Cannon
    October 18, 2011 at 11:00 pm
    The XML import is getting pretty good in 8.0 and 8.1, and might save some conforming time to use XML instead of EDL.
    KC
    Prehistoric Digital
    PhD Grading Suite
  • Brian Breheny
    October 18, 2011 at 11:17 pm
    To be honest the EDL conform was easy in Resolve.It is much better in 8 though.
    The biggest issue we had was monitoring.We had a Eizo CG241w and then Eizo lent us a CG232W which was great and then it was a matter of test screening our DCP for black levels
