Workflow for LARGE edit shot on 7D and XF300
Hi all,
Firstly I wanted to say thank you to all the contributors to this great resource. I have often come here with a problem or question and this is the first time I have needed to post that question as previously I have already found the answers here.
But this is a bit more of a specific question…
So here is the scenario:
We have just returned from a 3 week shooting trip gathering footage for a new multi screen audio visual performance we are putting together. We had 3 7Ds and and XF300 and needless to say we have returned with a vast amount of data – nearly 2tbs before any transcoding.
Initially I thought I could bring the 7D footage (the bulk of the data) in natively and make an initial selection and then transcode only what is usable and work from there. But it has quickly become apparent that this isn’t going to work. I would be happy with slightly sticky playback at this stage but FCP is continually crashing.
And now I am a bit stuck as to the best way to move forward. These what I see as my options:
1. transcode everything into prores and buy lots of external drives.
2. Transcode everything into prores and find a better storage solution, ie a multi drive Raid.
3. Invest in Final cut sever and begin our edit process there in a more offline way.
4. Set up an offline edit through FCP.
5. Use log and transfer in FCP and trim clips to the usable bits.
My hesitation to pro res everything, apart from the amount of data and time, is because its very documentary i know there is a lot of bits where nothing is happening etc. It is also worth mentioning that it won’t be a traditional linear edit. After this initial selection and putting together some lose sequences, we plan to collage and composite a lot of our footage together in After Effects and other processes.
We are running FCP 7.0.3, OS X 10.6.7 on a 2×2.6 Ghz Quad-Core Intel Mac Pro with 8GB Ram.
Any comments or work flow suggestions much appreciated.
Many thanks,
Tim
