Activity Forums Avid Media Composer workflow for exporting/compressing files for web
  • workflow for exporting/compressing files for web
    Posted by Dale on July 20, 2006 at 12:03 am
    Just wanted to throw my workflow out there to do with compressing video for the web (progressive download)
    I’m new to it- reasonably happy with my results but thought i’d run a few things up the flagpole.
    I export out of avid as QT movie (animation best quality) 320×240 and select sq pixel 16×9.
    Sorenson- I just use the presets- Large- about 900kpb/s, medium about 400kpb/s, small about 200 kpb/s. This encompasses QT, Windows media, MPEG4 and Real Media.
    My q’s…
    1: the presets though a little “furry looking” seem a fair quality but is it worth squeezing a little more out of them? (I’m working in dv25)
    2: In regards to 400kb/s what can this file type be used for? reading around the forums here suggests 200 kpbs for dial up and around that 900kb/s for broadband.
    3: is it worth deinterlacing the files being they will play on progressive computer monitors?
    4: the producer has enquired with me about increasing the screen size of the 200kb/s file… is it worth trying this or should dial up people just have to deal with a tiny size?
    5: Any other worthwhile tips- if u have time?
    Regards,
    Dale…
    Jon Zanone replied 20 years, 2 months ago 2 Members · 1 Reply
  • Jon Zanone
    July 20, 2006 at 11:28 am
    First, I would come out of the Avid at 720X480 – no sense in compressing your file twice. I’d also use QT reference – especially if you are encodeing on the same computer. The reference file is a pointer and uses the original OMF files, so you start with a higher quality, especially important with DV. Basically, all your settings coming out of the Avid should be same as source.
    There is a filter in Sorenson (depending on which version, it’s either a little wrence at the top of the window or a preset you can create) I set to NOT deinterlace. I’ve had great success with that.
    As for the presets, they’re fine – I suspect once you come out of the Avid with a larger file, you’ll see a noticable increase in quality.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
