Activity › Forums › Apple Final Cut Pro › workflow for editing multiple takes of one scene
  • workflow for editing multiple takes of one scene
    Posted by Kyrina Bluerose on December 15, 2018 at 11:28 am
    I have 5 takes of one scene. In music, the audio lines up perfectly (auto or manual synch) for multicam editing, but in acting, the timing changes. Would I put a marker on each clip for each line and ctrl+v around a timeline with 5 stacked clips? (in this case, 10; I had two cameras & have synched audio and lined those up.)
    Much appreciation for your sharing your admirable knowledge!
    Joe Marler replied 7 years, 9 months ago 3 Members · 3 Replies
  • Jeff Kirkland
    December 15, 2018 at 7:08 pm
    This is one place to use auditions. Stack the takes up and switch as you play. Personally though., I tend to just drop the best take on the timeline and grab bits of other takes as needed to replace the parts I don’t like.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Kyrina Bluerose
    December 15, 2018 at 7:14 pm
    Good ideas; thank you!
    I will research what auditions are.
  • Joe Marler
    December 16, 2018 at 1:56 pm
    Auditions don’t work with multi-cam, and I think your material is two-camera plus separate audio. There are several possible workarounds. These are just ideas, maybe someone has a better approach.
    In the Event Browser you could simply draw ranges over each “take” in the multi-cam and keyword that. Then click on each keyword in the left sidebar to rapidly switch between takes. If you want to see all the sub-clips in the Browser at the same time, create a keyword smart collection. You could quickly skim from take to take, without even being on the timeline. Then when you decide which one is best, put that on the timeline.
    If you want to combine parts of different takes, you could also do that. E.g, favorite or keyword the preferred “take fragments” as you skim each take in the Event Browser, then add those to the timeline and fine tune them.
    A keyword smart collection can be either library-wide (aka “Library Smart Collection”) or within a single event. This article discusses how to make them: https://larryjordan.com/articles/fcp-x-library-smart-collections/
