Activity › Forums › Adobe Premiere Pro › Workflow for converting NTSC to PAL with Premiere/AME
  • Workflow for converting NTSC to PAL with Premiere/AME
    Posted by Mike Tomei on July 13, 2010 at 6:58 pm
    Hi everyone,
    After searching the forums, I see that to convert NTSC to PAL for standard def DVD, most recommend using Canopus Procoder software for the MPEG2 encoding, or using a hardware based solution. I don’t have the money for those options, so I was hoping you could clear up something for me. Which of these options is best?:
    Option #1: import the NTSC footage into Premiere and edit on a NTSC timeline with settings matching the original footage. Then use Adobe Media Encoder to encode a PAL format MPEG2 file for the standard def DVD.
    Option #2: import the NTSC footage into Premiere and edit on a timeline set up with PAL resolution and framerate settings, and simply scale up the NTSC footage to match the larger PAL resolution. Then use Adobe Media Encoder to encode a PAL format MPEG2 file for the standard def DVD.
    Thanks for the help!!
    Mike
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    Adobe CS 5
    Eric Jurgenson replied 16 years, 2 months ago 2 Members · 1 Reply
  • Eric Jurgenson
    July 14, 2010 at 3:20 pm
    After Effects will do a better job than Premiere for this (if you have it). Better scaling, and smoother frame interpolation.
