Activity Forums Apple Final Cut Pro Legacy workflow for audio mix
  • workflow for audio mix
    Posted by Kevin on September 8, 2005 at 7:57 pm
    I am exporting an OMF file for an audio mix in Pro Tools. What is the best workflow and insurance that I can properly resynch the audio after I get the ProTools file?
    Is it simply lining up a 2-pop or is there something else I should be thinking about or that will work better?
    Thank you.
    Kevin
    G5 dual 1.8
    2 gig RAM
    FCP 4.5
    Bret Williams replied 21 years ago 4 Members · 4 Replies
  • Kevin Monahan
    September 8, 2005 at 8:12 pm
    Yes, that’s all you need to do. However, once you import the audio mix into PT, all your levels and keyframes will be gone. The new version of Automatic Duck allows you to bring those levels in intact. It’s nice.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Kevin
    September 8, 2005 at 8:48 pm
    great, thank you very much.
    I also have a ridiculous question: I am searching for a countdown/2-pop I can throw in at the beginning of the timeline…does FCP have a QT of one, or do I need to find my own?
    Thank you…
  • Chris Poisson
    September 8, 2005 at 9:24 pm
    Kevin,
    I believe there’s a countdown in your install disc, I think it’s in extras.
  • Bret Williams
    September 9, 2005 at 12:00 am
    Why not just put a single frame of tone?
