Workflow for 16mm Short
Hi all
I am editing a 16mm short film with Final Cut Pro 7.0.3. From telecining we were given a copy the rushes as two Uncompressed 10 bit Quicktime files at 25fps, Upper field first.
I wanted to edit with proxies and online to the original uncompressed media so that the colour grader has the highest quality file to work with.Using Compressor I made two Apple ProRes 422 (Proxy) files (as Log and Transfer doesn’t recognise Quicktimes).
I synced these in Final Cut making subclips and merged clips.I tried doing a test online. But I’m not able to Batch Capture because I didn’t use Log and Transfer initially (and I my full res media isn’t on tape). I wasn’t able to manually Reconnect Media (probably due to me labelling my subclips).
I could simply work with Apple ProRes 422 (HQ) files and avoid the offline and online-ing process. But doesn’t that defeat the purpose of shooting on film?
I would appreciate hearing what workflow others have used with similar projects. Any tips greatly appreciated.
THANK YOU!
