Activity Forums Apple Final Cut Pro Legacy Workflow Dilemma
  • Workflow Dilemma
    Posted by Michael Colin on March 24, 2007 at 4:39 am
    Greetings, all. Interesting situation.
    1) Client working on FCP for doc he wants to blow up to 35mm.
    2) Every flavor of source video under the sun. You name it, he’s got it. Right now I’m just trying to get it all into DV-NTSC for organization and offline.
    3) MANY clips submitted as muxed MPG1 on CD. From PAL country, so 25fps.
    4) Trying to find best way to demux the MPG1 clips, convert to 29.97, maintain sync and get reasonable quality video.
    CURRENT BIG PROBLEM
    Can demux the files in MPEG Streamclip and export out to DV-NTSC, but it looks like crap and audio drifts out of sync.
    Any ideas? Thanks!
    Michael Colin
    Rennie Klymyk replied 19 years, 6 months ago 4 Members · 3 Replies
  • Rafael Amador
    March 24, 2007 at 5:05 am
    Hi Michael,
    MPG1 is a 320×240 pixels format and you can not get much from it. If you go to re-edit the files I would recommend you to de-mux them and export to QT but to a better codec than DV (DV50 or 8b Unc) and in PAL. Them do the transcoding to NTSC with Nattress Standar Conversion.
    Cheers,
    rafael
  • Jason Lyons
    March 24, 2007 at 7:45 am
    Depending on the overall asthetic of the doc, a simple solution may be to use a camera and shoot computer monitor and make sure to capture the audio cleanly. Personally, this allows for more creativity and allows you to quickly and easily conform to NTSC.
    hope this helps
    j
  • Rennie Klymyk
    March 24, 2007 at 9:45 pm
    Mpeg1 was the 1st mpeg format and was designed to achieve a 352×240@1,5mb/s data rate(25fps). It does however support resolutions up to 4095×4095. Mpeg 2,4, 21 etc. are all improvements to this forerunner and are much more sophisticated and complex. It is used primariliy for video cd. It is the most compatible mpeg format and should play in most dvd players. It is typically vhs quality. Try playing in a dvd player and dubbing to your dv deck with the video out connections. You may find that your dvd player decodes it and plays it out as video better than a program like steamclip will convert it. Keep in mind when trans-coding files Mpeg 1 is PROGRESSIVE ONLY. You may find a pal dvd player does the best job. Decoders in dvd players are not all equall. Some lean toward dvix, others video cd etc. You could go to a retailer and try it in different players. (you may recall when dvd-r and dvd+r discs came out and burners became affordable, not all dvd players on the market would play them)
    Although I don’t recall ever making a video cd, my MediaPress Pro system can produce Mpeg1 files with almost as much control as mpeg2 files. Bit rate, VBR bitrate; GOP pattern, size, structure are all variable and formats in 1:1; 4:3 and 16:9 are available. There were tons of movies distributed in this format throughout Asia around the turn of the century.
