Activity Forums Apple Final Cut Pro Legacy Workflow Decision Time – XDCAM EX
  • Workflow Decision Time – XDCAM EX
    Posted by Anthony Koelker on September 23, 2009 at 7:57 pm
    I’m about to start a one hour show. It’s got a PBS affiliate behind it so it will probably have a regional airing. It will go to DVD also.
    It was all shot with the XDCAM EX3 at HQ 1080/30p. All the footage has been re-wrapped as Quicktime and ready to go. I’ve read literally a hundred threads but need to ask the question myself. Once I start, there is no turning back.
    My system is a MacPro Quad-Core Intel Xeon, 2.26 GHz, 12 GB of memory. I’m running Snow Leopard and FCP7 after an erase and install. My drives are LaCie d2 Quadras connected via FireWire 800. I also have a Kona LHi (and the best tech support I could ask for from them).
    There will be some work necessary in Color and a fairly extensive use of plug-ins as it is a period piece. I want to maintain the best quality but need to avoid lengthy renders for my sanity.
    I’ve done three codec tests. Fundamentally, it seems like the question is whether to convert at the beginning or at the end of the edit.
    The options:
    1) Work in the re-wrapped XDCAM EX format and export whatever I want when the job is done. This makes every layer of video above track 1 a render. I believe I understand that the long GOP format is very processor intensive and is a cause. I’ve also read threads that say this is THE way to work and it’s not a problem. I could be missing a crucial setting in FCP, if that’s the case.
    2) Use Compressor to compress all the footage to ProRes 422 at 1920×1080. Use the “Easy Setup” in FCP of AJA Kona LHi – 1080i 29.97 Apple ProRes 422. Or, better yet, since Kona doesn’t have a profile in 1080 for progressive, use a”Custom Setup” with Apple ProRes 422 1920×1080 30p? When I’m done, I’d export a 720p version for broadcast.
    3) Use Compressor to compress all the footage to ProRes 422 at 1280×720 progressive and use the “Easy Setup” of AJA Kona LHi – 720p 59.94 Apple ProRes 422.
    I think Option 1 is out due to the render issue. Is there a downside to Option 3? If drive space is not an issue, should I go with Option 2? Are there any parts of the puzzle I’m overlooking? I appreciate any guidance. Thank you.
    A.J. Koelker
    Aiken, SC
    “South Carolina – Too small to be a country, too big to be an insane asylum.”
    Bob O’brien replied 16 years, 11 months ago 8 Members · 8 Replies
  • 8 Replies
  • Bob Flood
    September 23, 2009 at 9:13 pm
    Anthony
    I too have been doing XDCAM ex and using FCP7 / leopard and i have found that either pro res OR xdcam require rendering, so i do not know if convertinf everything to pro res is going to save you a bunch of time.
    besides its just one more place where the media can get f***ed up!
    Wht the convenetional wisdom has been, and I have found this to work out, is to work in XDCAM ex, BUT use ProRes 422 as your compressor in your sequence settings. It renders faster than an XDCAM EX compressor,
    I would do some tests as to your best codec to export with. I ran a test once and it seemed that either one was about the same speed (the only difference was that the indicator bar moved more steadily on the Pro Res export) Your mileage may vary
    but the xdcam sequence withan alternate faster render codec has proven succesful to many
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Alex Elkins
    September 23, 2009 at 9:30 pm
    Hi Anthony,
    I work with XDCAM EX material every day and would chose Option 1 for sure. Converting everything to ProRes will take so long that I’d be surprised if it saved you any time at all.
    [Anthony Koelker] “When I’m done, I’d export a 720p version for broadcast.”
    Do broadcasters in the US accept 720p deliveries? I’m in the UK and all HD programmes I’ve edited are delivered 1080i, even when shot 720p – your Kona card will handle this conversion excellently.
    All the best,
    Alex Elkins
  • Mark Raudonis
    September 24, 2009 at 1:27 am
    I agree with BF.
    We’re currently using the XDCAM HD codec for just about ALL of our work. (1 hr reality TV shows) While most of the material is shot XDCAM HD 50 , there’s a fair amount of material coming in from EX 3’s as well. Even with this mix of codecs, our workflow is the same. We work in an XDCAM timeline, but set rendering to PRORES.
    I’m aware that plenty of people have had issues with XDCAM timelines, but we have been able to develop worklfows, practices, and procedures to minimize the pain. For example, we do a “proactive restart” at lunch time. We “Bake in” complex effects, speed changes etc.
    It sounds like your systems are new enough and up to spec to handle this format.
    Good luck.
    Mark
  • Jason Porthouse
    September 24, 2009 at 11:40 am
    I can only chime in here with my experience. I, along with many others, have had terrible problems with crashing working natively with XDCam. We had a meeting at the production company yesterday with a local FCP guru who has had issues too; his workflow now is to trascode all XDCam to ProRes (not HQ) and work in that. It’s something we’re going to adopt across the board in order to try and stabilise things.
    Now, this is in PAL land and there are many who don’t seem to get the issues we’re finding. If that’s the case for you then working natively may be the way to go; unfortunately you won’t know ’till you try. If you do go that way and experience random crashes, then turning off thumbnails in the TL and not using Icon view in the bins seems to lessen the problem. I think it’s an issue in writing the icons (they change whenever in/outs are altered) but as I say many haven’t encountered this issue.
    In your shoes, given my experience, I’d transcode to ProRes 1080 before starting. But YMMV, and you may use option 1 with no issues at all…
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Steve Connor
    September 24, 2009 at 1:00 pm
    I’m one of those people who are working with all flavours of XDCam, using native timelines (but ProRes to render!) with no issues.
    However I don’t use Icon view in the browser (old habit) and I’ve switched off thumbnails in the timeline.
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Michael Allen
    September 24, 2009 at 1:48 pm
    The problems must be related to the EX part of the equation. I have been using the Sony F350 since it first came out and have experienced no problems with native XDCam HD editing. In fact, I am very impressed with the imagery and workflow. Now crashes what so ever with regular XDCam HD editing over here in the last 2 years. Is the EX codec a little different?
    Mike
  • Bob Flood
    September 24, 2009 at 3:16 pm
    Mike
    My understanding is that XDCAM HD is a variation on MXF, ie MPEG2 compression, but all I frames, so each frame is independent, just like any motion jpeg codec.
    HOWEVER EX is more like HDV, in that its MPEG4 using I B amd P frames, so the CPU has to work a lot more to “fill in the blanks” when ediitng, making up B and P frames and making them editiable.
    hope this helps
    Bob Flood
  • Bob O’brien
    September 24, 2009 at 3:40 pm
    If picture quality isn’t a big issue while editing, you could also set your render settings to 50%. Renders will go much faster. When your done editing, set them back to 100% and render overnight.
    Bob
    CAMERAS
    Sony EX3 & Sony DXC637/PVV3 Betacam-SP
    PORTABLE EDITING
    *MacBook Pro – 2.33Ghz – 2Gb RAM
    *Matrox MXO / 23″ Cinema Display
    DESKTOP
    *DualG5 2Ghz w/2.5Gb RAM
    *UL4D SCSI Card
    *HMV800 DualMax RAID0
    *AJA IO
    *Sony 2800
    SOFTWARE
    *OSX10.4.11, QT 7.5, FCP 6.0.4, Livetype 2.1.3, Soundtrack Pro 2.0.2, DVDSP4.2.1, Adobe CS3 Prod Suite
