Activity › Forums › Adobe After Effects › Workflow between AFX and PPro
  • Workflow between AFX and PPro
    Posted by Rhys Sherring on May 30, 2016 at 11:36 am
    Hey CC community.
    So I’m putting together a short fictional advertisement for my short film using HD footage from a Blackmagic 4K, cutting it together in Premiere Pro. I’m finding myself going back and forth quite a lot between PPro and AFX because I’m doing a lot of transition effects. I was wondering if anyone could give me some advice on the most efficient workflow between the two programs.
    My process so far: I’m importing the footage into PPro and cutting the scenes on individual sequences. I then go into AFX and dynamic link import PPro sequence and do some transition effects. I then add to render cue and export as a lossless high quality quicktime PNG to bring back into PPro to try and refrain from losing quality. I’m planning to XML export the PPro sequence into Davinci resolve for a colour grade and bring it back into PPro for sound work and final export.
    Thoughts?
    Michael Szalapski replied 10 years, 4 months ago 2 Members · 1 Reply
  • Michael Szalapski
    June 1, 2016 at 12:55 pm
    I would do most of what you’re doing except for the Dynamic Link part. I prefer to simply use the Import>Import Premiere Pro Project command. That way I have each cut on its own layer which I find easier to work with.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
