Activity Forums Adobe After Effects Workflow between Adobe Premiere Pro and After Effects
  • Workflow between Adobe Premiere Pro and After Effects
    Posted by Tommy on August 2, 2005 at 5:19 pm
    I can`t quite get the workflow between Adobe Premiere Pro and After Effects. This is what I do:
    Question 1:
    1. I start of by importing footage from my camcorder.
    2. Then I am editing it in premiere pro
    3. Then I export it as an .AVI file on my computer.
    Everything works fine until now.
    4. The next thing I want to do is to apply the magic bullet filter so I can get a movie look. Then I press ctrl+alt+0 and apply my comp. Then I export it out and save it.
    (Why cant I see this footage in windows media player, it has big problems of playing It.)
    5. Here is when the problem accure. I then again export it to premiere to export it to mini dv or burn it out on dvd. What happens is that I have to render it AGAIN. And everything works SOOO slow on my computer. The render takes forever.
    Is there something wrong with my workflow? Is there a better way?
    Question 2:
    Why does it not look like widescreen when I Import it as widescreen into AAE in a comp that is for widescreen??? It get the look of standard footage..
    Thanks!!
    Tommy replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
