Activity › Forums › Adobe Premiere Pro › Workflow APP 1.5 + Illustrator Cs2…
  • Workflow APP 1.5 + Illustrator Cs2…
    Posted by Uwe Lansing on December 29, 2005 at 11:28 am
    can anybody explain an effective workflow between APP + Illustrator CS 2. I want to change the frames of a short clip into vector graphics with Live-Tracing (palettes etc.) and then reimport to APP. Obviously Illustrator can
    George Loch replied 20 years, 9 months ago 3 Members · 3 Replies
  • Steven L. gotz
    December 29, 2005 at 11:47 am
    You can export as a series of stills. How short a clip? At either 25 or 30 frames per second, it adds up.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Uwe Lansing
    December 29, 2005 at 1:02 pm
    Thank you. Yes, the problem is to handle maybe 5 sec (125 tiffs =>Pal) inside of Illu CS2, how to export + than import in APP. I think, there must be a shorter way than edit every single frame in Illu (like export as Filmstrip in APP, import as Flm in Photoshop….)…?
  • George Loch
    December 31, 2005 at 6:18 am
    I think it would be faster to export a single still and draw the art in Illustrator then animate it in AE.
    -gl
