Activity Forums Apple Final Cut Pro Legacy Workflow Advice for Cable Program
  • Workflow Advice for Cable Program
    Posted by Gtv2000 on September 12, 2006 at 3:45 pm
    I hope you can help me set up a proper workflow for a program that will be broadcast on cable.
    The program was shot on 35mm film and dumped to Digibeta. I am working with Beta SP copies of the Digibeta dubs because I have a Beta SP deck but not a Digibeta deck.
    I would like to know the best way to capture and ultimately output the program for the best quality.
    Here’s my setup:
    FCP 4.5
    1 Terabyte G-Raid (800)
    1 800 GB G-Raid (800)
    PowerBook G$ with LaCie 800 card
    Sony UVW 1800 Beta SP deck
    Sony DSR 80 DV Deck
    AJA IO LA
    The final program will be approximately 6 hours in length, but can be broken into smaller segments. I would like to capture into DV timeline from Beta SP source. Should I take the DV timeline to an online facility to uprez for final output to Digibeta, or should I take the EDL to a house that can re-capture all Digibeta source footage for final output to Digibeta? Would outputting to Beta SP be acceptable rather than Digibeta? Is standard dubbing practice to match TC on a Digibeta to Beta SP transfer?
    Thanks very much for any help.
    David Roth weiss replied 20 years ago 3 Members · 4 Replies
  • David Roth weiss
    September 12, 2006 at 5:09 pm
    [gtv2000] “Should I take the DV timeline to an online facility to uprez for final output to Digibeta”
    Absolutely not!!! That is a certain way to insure the worst quality. One way or another you should absolutely online from the Digibeta original. Furthermore, cutting on a DV timeline is a bad idea too. I would suggest capturing and cutting at nothing less than 8-bit uncompressed, that way all your graphics will remain uncompressed throughout the entire post production process.
    DRW
  • Gtv2000
    September 12, 2006 at 5:22 pm
    I think I have too much footage (6 hour finished run time) to capture uncompressed on a total of 1.8 terabytes?
  • Kevin Monahan
    September 12, 2006 at 11:07 pm
  • David Roth weiss
    September 12, 2006 at 11:32 pm
    [Kevin Monahan] “Drives are cheap.”
    I’m onboard with Kevin on this one completely. With excellent 500gb SATA drives at just $179.00 each these days, no project, especially one shot on 35mm film, should suffer a major quality hit because drive space is an issue.
    DRW
