Activity Forums Avid Media Composer Workflow advice
  • Workflow advice
    Posted by Manny Jonson on June 19, 2009 at 4:08 pm
    Hi
    Would be great to get some advice on a workflow for me and my editor.
    We’re making a ten minute short, shot on 35mm. After processing we will be cutting from DVcam tapes that correspond to lab rolls, once we lock picture we are going to conform and grade by scanning the neg elements in 2k then master to HDCam Sr and spit out a negative.
    Is there anything we need to take into consideration when going this way while cutting on Media Composer? I’m assuming we just take the EDL with us to the Scan right?
    THanks
    Manny
    Michael Phillips replied 17 years, 2 months ago 2 Members · 3 Replies
  • Michael Phillips
    June 19, 2009 at 5:55 pm
    Bascially a good EDL, Avid FilmScribe can generate a pull list/scan list directly that can be handed over to a facility. Are you editing native 23.976/24 or at NTSC/PAL rates?
    Michael
    Michael Phillips
  • Manny Jonson
    June 19, 2009 at 10:01 pm
    Hi
    We’re in the UK so I assume it’ll be 25fps, can you go into more detail regarding pull down etc please?
    thanks
  • Michael Phillips
    June 19, 2009 at 10:59 pm
    If in 24/25 there is no need to track pulldown rates as that is a 24/30 issue. Just make sure you are tracking the 24fps correctly in the SD project via the TC24 column.
    Michael
    Michael Phillips
