Activity › Forums › Apple Final Cut Pro Legacy › Workflow Advice
  • Workflow Advice
    Posted by Chad Tingle on October 4, 2010 at 3:53 pm
    I recently inherited a multi camera project that was shot on three different formats. It’s a Jazz concert shot on a DVX100B (with an anamorphic lens, A panasonic HDX900 shot at 720 24p and a Canon 7Ds @72060. So I’m dealing with H.264, DVCPROHD and Anamorphic DV. My plan is to try to Upconvert the anamorphic DV to 720 apple pro res Using my Kona LHI, Capture the DVCPROHD footage to pro-res and convert the Canon footage to pro-res. I would work with all the footage at the 59.94 base frame rate. I figured if I made all the footage 720 59.94 then I could take advantage of the multi-camera function in FCP. This is not exactly the way I would have done it but it’s a longtime client and I want to do my best to help them I’m looking for some advice on whether I could run into any pitfalls or if someone has a better idea i’m open to any suggestions.
    Chad Tingle
    Producer/Editor
    Chad Tingle replied 15 years, 11 months ago 2 Members · 2 Replies
  • Kris Merkel
    October 4, 2010 at 9:29 pm
    I would throw out the notion of trying to edit a multiclip sequence for this project since you will have 3 different timecodes.
    Do all of your masters have audio on them? including the 7D? If so, once you have have all your footage normalized you could sync in the timeline with pluraleyes.
  • Chad Tingle
    October 4, 2010 at 9:36 pm
    I heard about Plural eyes and did some research I while back I’ll check it out
    Thanks Kris
    Chad Tingle
    Producer/Editor
