Activity › Forums › Avid Media Composer › workflow 4k to be exported in 1080
  • workflow 4k to be exported in 1080
    Posted by Federico Palumbo on May 18, 2018 at 11:07 am
    Hi I have 4k footage to be finally exported in 1080. I work with Avid, I would to know best workflow to have reframe option with some footage. I have also an old mac so please consider… i need proxy? i have time to make any possible conversion and need procedure that help me to work with my low performance old mac.
    Than i need to pass some footage to after effect, and last i will make color correction with davinci.
    thanks
    Federico
    Robert Ober replied 8 years, 1 month ago 3 Members · 2 Replies
  • Shane Ross
    May 18, 2018 at 7:50 pm
    Cut in a 1080 project. Bring the footage in as DNxHR HQ at 4K. OR…if you need to work Proxy, there’s a codec for that, AMA link the footage and then transcode to DNxHR LB….and then relink to the masters and transcode to HQ when done. This way you keep the 4K size but work in 1080, so can use Frame Flex to reframe shots as needed.
    If you need to pass footage to AE, then working HQ would be an option…but this all depends on if your machine can handle it. If not, then you’ll have to send the camera master to AE…matching the timecode to find the right spot.
    Shane
    Little Frog Post
  • Robert Ober
    August 22, 2018 at 6:39 pm
    And if it’s real 4K, not UHD you will need the Studio version of Resolve. The standard free version of Resolve only works up to UHD.
    Take it EZ,
    Robert
