Activity Forums Square Box CatDV Worker // Server Job // Shared Clip Lists // How ?
  • Worker // Server Job // Shared Clip Lists // How ?
    Posted by Leonid Nekrasov on June 12, 2012 at 8:20 am
    Hi everybody,
    is there a way to make Worker to recognise, that one Clip belongs to a particular Shared Clip List? I couldn’t find any Metadata pointing on affiliation to the Clip List.
    Thx
    Leo
    Leonid Nekrasov replied 14 years, 2 months ago 3 Members · 3 Replies
  • Bryson Jones
    June 12, 2012 at 3:46 pm
    Lots of metadata isn’t exposed. It only exists for internal use. From what I can see, that’s one of them.
    There are tons of these items that serve different purposes but aren’t part of the actual metadata schema.
    A metadata tag and a saved search is really the replacement for this as far as a way to create searchable “clip lists”.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Rolf Howarth
    June 15, 2012 at 10:40 pm
    Currently the worker doesn’t use clip lists I’m afraid. What are you trying to do – query for clips based on the clip list they are in, or add clips to a clip list from the worker?
  • Leonid Nekrasov
    June 18, 2012 at 7:10 am
    I want worker to query for clips based on a clip list and convert them in a particular format. Clip list is a great Tool for our editors to search for a footage and to collect it in an easy Drag&Drop way for a later edit. The best thing on a clip list is that, there is no danger, that the original clip can be moved. That can happens, if I use Catalogs. And you know… we have editors that just still cannot understand the difference between move and copy to another catalog 🙂
    Regards
    Leo
