Activity Forums Square Box CatDV Worker Node “No server queries defined”
  • Worker Node “No server queries defined”
    Posted by Martin Newsome on August 3, 2011 at 10:00 pm
    When adding a second Work set, why does CatDV Worker Node (3.1.0) grey out the Server monitor and display “No server queries defined” ?
    The first work set has four actions and one Watch action.
    I want to create a second to Work set to group separate workflow tasks. This new set will contain four Watch actions.
    Thanks for the help.
    Bryson Jones replied 15 years ago 2 Members · 1 Reply
  • Bryson Jones
    August 4, 2011 at 6:21 am
    I’m pretty sure that’s the correct behavior.
    If you don’t create a “server query” I don’t believe that will become active. There’s no need for it.
    If you define any Server Query, it should light up and be checked.
    The three boxes correspond to the different parts of the app but if you’re not using either the watcher or the server queries, you can leave them unchecked.
    Check that, and report back if there’s a problem.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
